Spindle nema 34 duet 2 wifi
@dc42 said in Spindle nema 34 duet 2 wifi:
Will a stepper motor provide sufficient speed and torque? Stepper motors are limited to a few revs/second due to back emf.
the stepper motor provides high torque at low revs which the vfd motor does not and this brings many advantages for my experience that I have done some technical tests
@paolozampini1973 @CNCModeller if there is enough interest then I can look at providing the option to run a stepper motor as a spindle in a future version of RRF. However, it's likely to be a Duet 3 feature only because of lack of flash memory on Duet 2.
reading on the forum I saw that there are people particularly interested in the DUET 2 WiFi As for removing plastics with a cutter, I have a lot of experience and also with turning, over time I have understood that high speed has many disadvantages It is better to work at low speed with some strategies you can achieve excellent results without lengthening the times excessively
@paolozampini1973 Duet2Wifi will not be able to fit new features due to space constraints.
@oliof said in Spindle nema 34 duet 2 wifi:
thanks for the answer can it be clearer please Thanks
@paolozampini1973
I think what that means is the memory within the Duet2 doesn't have adequate capacity to store the additional code required.
