Issues with Duet 2 Wifi or Duex5
I just purchased an e3d Tool changer from Filastruder. I have it all built. I can't get T2 to heat up. I have it all wired per the guide. So it is on Duex5. When I switch it around to other plugs it works. So to me looks like Duex5 might be bad.
Would be good to include photos of the boards showing the wiring, and upload your config file.
Here is the config.g
; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
; executed by the firmware on start-up; General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M667 S1 ; Select CoreXY mode; Network
M550 P"ToolChanger" ; Set machine name
M552 S1 ; Enable WiFi Networking
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Drive direction
M569 P0 S0 ; Drive 0 X
M569 P1 S0 ; Drive 1 Y
M569 P2 S1 ; Drive 2 Z
M569 P3 S0 ; Drive 3 E0
M569 P4 S0 ; Drive 4 E1
M569 P5 S1 ; Drive 5 E2
M569 P6 S1 ; Drive 6 E3
M569 P7 S0 ; Drive 7 COUPLER
M569 P8 S0 ; Drive 8 UNUSED
M569 P9 S0 ; Drive 9 UNUSEDM584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
M208 X-35:328.5 Y-49:243 Z0:300 C-45:360 ; Set axis maxima & minima
M92 X100 Y100 Z1600 C91.022 E834:834:834:834 ; Set steps per mm assuming x16 microstepping
M350 E16:16:16:16 I1 ; Configure microstepping with interpolation
M350 C16 I10 ; Configure microstepping without interpolation
M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
M906 X1800 Y1800 Z1330 I30 ; Idle motion motors to 30%
M906 E1000:1000:1000:1000 C500 I10 ; Idle extruder motors to 10%; Endstops
M574 X1 Y1 S3 ; Set X / Y endstop stall detection
M574 C0 Z0 ; No C Z endstop; Z probe
M558 P8 C"zstop" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X10:290 Y20:180 S40 ; Define mesh grid;Stall Detection
M915 X Y S3 F0 H400 R4700 ; X / Y Axes; Heaters
M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor
M950 H0 C"bedheat" T0 ; Bed heater
M143 H0 S225 ; Set temperature limit for heater 0 to 225C
M140 H0 ; Bed heater is heater 0M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 ; Set thermistor
M950 H1 C"e0heat" T1 ; Extruder 0 heater
M143 H1 S305 ; Set temperature limit for heater 1 to 300CM308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8 ; Set thermistor
M950 H2 C"e1heat" T2 ; Extruder 0 heater
M143 H2 S305 ; Set temperature limit for heater 2 to 300CM308 S3 P"e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8 ; Set thermistor
M950 H3 C"duex.e2heat" T3 ; Extruder 0 heater
M143 H3 S305 ; Set temperature limit for heater 3 to 300CM308 S4 P"e3temp" Y"thermistor" A"T3" T100000 B4725 C7.06e-8 ; Set thermistor
M950 H4 C"duex.e3heat" T4 ; Extruder 0 heater
M143 H4 S305 ; Set temperature limit for heater 4 to 300C; Tools
M563 P0 S"T0" D0 H1 F2 ; Define tool 0
G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0CM563 P1 S"T1" D1 H2 F4 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0CM563 P2 S"T2" D2 H3 F6 ; Define tool 2
G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0CM563 P3 S"T3" D3 H4 F8 ; Define tool 3
G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C; Fans
M950 F1 C"fan1"
M950 F2 C"fan2"
M950 F3 C"duex.fan3"
M950 F4 C"duex.fan4"
M950 F5 C"duex.fan5"
M950 F6 C"duex.fan6"
M950 F7 C"duex.fan7"
M950 F8 C"duex.fan8"M106 P1 S255 H1 T70 ; T0 HE
M106 P2 S0 ; T0 PCF
M106 P3 S255 H2 T70 ; T1 HE
M106 P4 S0 ; T1 PCF
M106 P5 S255 H3 T70 ; T2 HE
M106 P6 S0 ; T2 PCF
M106 P7 S255 H4 T70 ; T3 HE
M106 P8 S0 ; T3 PCFM593 F42.2 ; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
;M376 H15 ; bed compensation taper;tool offsets
; !ESTIMATED! offsets for:
; V6-tool: X-9 Y39 Z-5
; Volcano-tool: X-9 Y39 Z-13.5
; Hemera-tool: X20 Y43.5 Z-6G10 P0 X-9 Y39 Z-2.84 ; T0
G10 P1 X-9 Y39 Z0.11 ; T1
G10 P2 X-9 Y39 Z-5 ; T2
G10 P3 X-9 Y39 Z-0.24 ; T3;M572 D0 S0.2 ; pressure advance T0
;M572 D1 S0.2 ; pressure advance T1
;M572 D2 S0.2 ; pressure advance T2
;M572 D3 S0.2 ; pressure advance T3M575 P1 S1 B57600 ; Enable LCD
G29 S2 ; disable mesh
T-1 ; deselect toolsM501 ; load config-override.g
Does the LED near the heater terminal in question on the Duex light up when heat is commanded?
@Phaedrux I am not seeing anything
Can you grab some photos of the board with the heater terminal area in particular?
The heater itself works when connected to another terminal, correct?
And the LEDs on the other terminals light up correctly?
@Phaedrux I will try to today or tomorrow. Still recovering here from all had over for turkey day.
I think I have it going now. Looks like wire wasn't going into the duex heater all the way. I was able to jam in it and now heats up.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
