Power Button
Greetings all.
I have not been able to print anything for several months and tonight I sat down to fire up my machine and do exactly that.
But before I did I visited this forum and seen that there had been several firmware updates since I've been away. I read back through the release notes and didn't see anything too specific that might would suggest changing the config files so I went ahead and upgraded.I was on v3.3 and just updated to 3.4.4.
I have the Duet2 Wifi.Now the power button for my ATX power supply has disappeared from DWC.
I read through the wiki and discovered that M80 and M81 now needs parameters set before they will work.
Specifically a 'C' parameter with a pin name to specify the power port. (if I am reading the wiki correctly)With that, can someone point me to some documentation to help me resolve this?
I have looked through search results for the past 30 minutes and it seems no one else has had this issue, unless I have typed the right terms into the search bar.Thanks in advance.
Have you seen this?
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m80-atx-power-onWhat pin are you using?
@Phaedrux
Thank you, sir.
I glanced over those docs before I asked this question, and I misunderstood it to mean that it was asking for a PIN number.
I didn't think about 'PSON' being the PIN name.All is well now.
Thank you! -
