PanelDue 7i wavy film
I just installed a PanelDue on my 6HC and it’s awesome, but it appears to have a wavy film that doesn’t appear to be fully adhered to something below it. I already removed one screen protector before installing it. Is this another screen protector I needed to remove or is it the digitizer, etc.
I can't quite tell from the photo. It doesn't look right though. Can you snap a clearer picture with the case off?
When and where did you purchase it?
@Phaedrux thanks for the reply. When I remove the screen from the case, the issue disappears. My theory is, when it’s in the case, the board twists and causes the digitizer to come off the screen. It was definitely the digitizer as I can tell now that it’s out of the case that the digitizer floats on the screen and is only attached at the edges. I ordered it from Printed Solid on 9/13/2022. I will drill out the mounting holes on the case to prevent it from twisting the board.
@Phaedrux just reporting back that it was definitely the issue. Once I drilled the holes out in the case and re-mounted the PanelDue, the issue was fixed. Thanks!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
