Duet 2 to Stratasys Interface
Re: Stratadue: Duet 2 to Stratasys Interface
Is where design files somewhere ??
@ViralTinker Check out this post by @Archeantus
https://forum.duet3d.com/topic/12647/another-stratasys-uprint-retrofit/40?_=1668262306531
DuePrint on Hackaday - Duet 2 and Duex5 integration into a uPrint, execution would be similar to a Fortus 250 / Dimension series printers.
https://hackaday.io/project/186419-dueprint -
@sebkritikel Thanks for the link .Good info,. Why would you want LIS3DH Accelerometer???
@ViralTinker RepRapFirmware supports Input Shaping, which allows for some resonance compensation - helping to reduce or eliminate print artifacts like 'ringing'
https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping
The Accelerometer is used to characterize what frequencies excite your 3D printer, helping to identify which frequency and input shaper to select to reduce 'ringing'. Entirely optional to implement for a Stratasys retrofit.
