Cannot print a file containing single quotes from DWC
Creating this post to link from github issue template:
Expected result
Can print files containing single quotes from DWC
Observed result
RRF responds with a file not found error and the single-quote is stripped out, the subsequent letter is lowercased if it is upper-cased
Steps to reproduce
Try printing any file containing single quotes from DWC's jobs tab.
This is caused by https://docs.duet3d.com/en/User_manual/Reference/Gcodes#quoted-strings which removes single quotes.
Thanks for the report. This should be fixed in 3.5.
