Wifi Periodically Disconnects?
@rogerpodacter are you running the same version of DWC as RRF firmware? Otherwise we will need @chrishamm to investigate what’s causing the memory leak.
@droftarts It doesn't have to be a memory leak. When running DWC for hours, Safari often advises me to close the tab because it consumes quite a lot of resources, I.e. power. In my case, that’s simply some load on the CPU. Given that @chrishamm permanently scans the Duet’s object model, that’s exactly what I expect to happen.
@droftarts yes i'm running DWC 3.4.2 and RRF 3.4.2.
and my wifi has not disconnected at since yesterday. so far so good.
