Voron 2.4 build with duet
Good day,
IMO the duet 3 6HC is overkill if you're not planning on going super fast or high accelerations (to the like of Vez3D etc on youtube)
I've done the Voron 2.4 with a duet 3 mini + 2x expansion, as well as the 1LC toolboard which simplifies wiring the gantry a lot. I'm moving the print head around at up to 300 m/s comfortably (haven't tested for more).
Anyway, the 1LC toolboard is a recommendation no matter what main board you get
Having a Duet3 6 HC on a CoreXY build
minding to add compatible accelerometer to your bom if you want
print faster than 60-80mm/sif youre going to add an 1LC toolboard to your printhead, it has an accelerometer inbuild
https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LCtheres also a guide for orientation by Nuramori:
https://www.dropbox.com/s/hu2w5mk57l4zqpg/Accelerometer Orientation.pdfWith input shaping actually tested are 300mm/s with a tolerance of 0.1 are possible
@sonderzugThanks still analysing my options
Will the 1LC toolboard be OK at the higher cabinet temperatures -
@r3shyThanks will check out the links
@james317 my chamber normally hits 50 degrees and its fine in that
@james317, I am using the mini5 + 2 Duet 3 and it works well for me. I have the standard drag chains and wiring with Teflon wires and am happy with it.
The CAN BUS toolboard may be a good choice but I didn't go with it because of its relatively large size.
I've designed a mount that integrates the 1LC toolboard to the new Stealthburner print head. I can share it however it is based on the pre-release STL models, and it is possibly flawed in that it doesn't support the tooboard on all four mounting locations and might allow for some vibration which crucially can throw off the accelerometer for tuning input shaping. Aside from that it's tidy and works well.
@sonderzug Hi my plan is to use LGX with the afterburner and toolboard
This post is deleted! -
@james317 Cool
@sonderzug Hi, did you share your file on github or thingiverse?
