Bug creating config with "Dual Stepper Driver Expansion Module"
Hi there,
I tried to create a new config for a Duet3 Mini5+ with the two stepper driver expansion module.
Unfortunately the config tool does not use the correct motor driver numbers.
Drivers on the main board are 0.0 - 0.4, for the expansion module 1.0 and 1.1 are used but according to the documentation here the drivers are numbered 5 and 6, so 0.5 and 0.6.I wanted to create a bug report on Github but that requires to created a thread here...
Cheers
Alexander -
one for @chrishamm
@alex9779 Thanks for reporting this, it is now fixed in v3.3.13. You may need to press
Ctrl+Shift+R
in the configtool tab to force-reload it, alternatively clear you browser cache once. -
Thanks, looks good
