Ultimaker Cura printing end problem.
I have a problem that happens to me when using Cura and it is that at the end of the print, just at the last point where the nozzle is passing, it stops and begins to retract the filament without stopping or moving in any direction for approximately 40 seconds . After this time, the printer executes the part presentation code without problems. I tried several laminators and it only happens at the end of printing a gcode from cura, the same does not happen with simplify 3d or with prusaslicer. Does anyone know what it could be? Attached is a photo of a calibration cube, where you can see the result of the problem.
You probably have Cura set to absolute extrusion and your end gcode has a retraction in relative extrusion which is causing the extruder to move to a very early absolute position.
The solution is to either add a switch to relative extrusion mode before your retraction in your end gcode, or better yet, switch Cura to use relative extrusion. Search the settings bar.
