Z-seam for PA tuning
I use Cura4.8 and i'd like to print a 100mm cube for PA tuning.
But i struggle to positioning the z-seam to the front!?I have positioned the z-seam and also layer start point in front. But cura does it always in the corner!?
Does somebody know why?Thanks in advance
In Cura you can define an XY position for the seam when it's set to user specified. You may need to unhide a setting. Can you show us what your cura settings for seam look like?
