Input shaping help
@jay_s_uk and can i delete the acc file in my system?
@jamaicarasta the file generated by the original accelerometer plugin? yes
@jay_s_uk yes first try without your tips
@jay_s_ukDo I understand that correctly, nothing is required in the system files. The M593 P"zvd" F46 command in the config file is sufficient.
@jamaicarasta correct
@jay_s_uk Thanks for your help man, now the Test print. That was the Print yesterday without shaper. 100mm/s and 7000accel. Not bad with 7000accel. Voron 350 with lgx lite and carbon x axis and 1 mgn12 rail.
