need Guru on duet 3 mini5 using stall guard/sensor less homing
@moth4017 said in need Guru on duet 3 mini5 using stall guard/sensor less homing:
No more Gurus out there playing with the Duet 3 mini5 tmc2209
I setup homing via stalling and it worked. Compared to an actual endstop sensor it made quite a thump.
I quickly installed actual endstop sensors.
I don't like thumps.
@moth4017 since you swapped the wiring as well it's hard to say.
I have the x y sensorless homing well just a gentle tap for homing,
the Z homing max also works with a gental tap, but sometimes the motor just stalls and doesnt move. -
@oliof
i suppose it rules out if it was a mechanical issue .. -
sure, but I would check the wiring on both ends anyways to ensure there are no bad crimps.
thats has caught me out in the past before , that would be a nice easy fix :), but not this time .
the Z homing max also works with a gental tap, but sometimes the motor just stalls and doesnt move.That suggests you are reducing the current too much (I assume you are reducing the current) which helps with obtaining the gentle tap but also may be creating the lack of movement.
Ive tried settings from low to high in the sensitivity H settings from 50 to 700 current from 10% to 100% .
it does seem to be 90% of the time the first stepper motor listed in M584 stalls
Well, that rules out that theory.
I don't use the "stall guard" feature and know only the basics.
Good luck.
