Filament sensor Meta Command issue
HI, I have a Duet 2 WiFi and it is on old Prusa MK2.5s hardware. so I am working out so details and I am using Kolbi's setup ( mostly) and some of his macros.
Now in a couple of his Macros found here:
https://forum.duet3d.com/topic/18002/zaribo-prusa-i3-mk3s-duet-2-wifi-rrf-3-11/15
(Specifically Set Filament Type and Filament Handling there is this line that is giving me errors:
if sensors.filamentMonitors[0].filamentPresent = truehere is the response for: m591 d0
Simple filament sensor on pin e0stop, enabled, output high when no filament, filament present: noWhen I run the Set Filament Macro I get this error:
M98 P"0:/macros/Set Filament Type"
Error: in file macro line 5 column 4: meta command: unknown value 'filamentPresent'When I run M409 K"sensors.filamentMonitors" F"filamentPresent"
I get this response:{
"key": "sensors.filamentMonitors",
"flags": "filamentPresent",
"result": [
"status": "noFilament"
"next": 0
}I know I am missing something, but what am I missing?
below is my
m122 "config.g"
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6M2-NW4SD-6J9F6-3SN6Q-KVQHK
Used output buffers: 3 of 24 (24 max)
Static ram: 23868
Dynamic ram: 74880 of which 204 recycled
Never used RAM 13128, free system stack 184 words
Tasks: NETWORK(ready,14.6%,242) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,85.4%,440) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
Last reset 00:30:23 ago, cause: software
Last software reset at 2022-05-08 21:12, reason: User, GCodes spinning, available RAM 9440, slot 2
Error status: 0x04
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 28.4, current 28.8, max 29.2
Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
Events: 1 queued, 1 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2022-05-08 21:42:53
Slowest loop: 7.06ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.3ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is ready with "m122 "config.g"" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0 sensor: no filament
=== Network ===
Slowest loop: 201.65ms; fastest: 0.08ms
HTTP sessions: 2 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 3
WiFi firmware version 1.26
WiFi MAC address f4:cf:a2:ea:8c:e5
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25112
WiFi IP address 192.168.1.104
WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
Found it:
Field "filamentPresent" is removed from those types of filament monitor that previously supported it. Use "status" instead. -
@jdebuhr said in Filament sensor Meta Command issue:
Found it:
Field "filamentPresent" is removed from those types of filament monitor that previously supported it. Use "status" instead.Hi,
I'm glad we were able to be of no help whatsoever.
Seriously though, where did you find the answer?
