Connecting a filabase silicon heater.
Hi
Im about to rebuild my bed with a filabase bed from filafarm.
Its a 230v silicon pad and it comes with a SSR.
My old was a 24v bed.Do I run same 24v Duet wifi output to control my SSR?
It seems as the termistor in my pad is a single wire 100k termistor, where on the Duet should I connect it?Going to ground my frame and put in a ground breaker too.
This post is deleted! -
@arnold_r_clark
Thanks for the info. Just need to figure out the one wire termistor to get going. -
@rogerl, a thermistor needs two wires. The way it works is that the electronics measure the resistance of the thermistor and that is impossible with a single wire. I would suggest contacting the supplier to see what is what.
@arnold_r_clark
You’re right, it was cut short inside the sleeve. Thank every one for the pointers. -
What kind of config did you guys use for the filafarm pad termistor?
@arnold_r_clark
Thanks Arnold, really appreciate the help.
