DCS not starting failed firmware
Ok I may have done something.
Picked up a e3d toolchanger and it had old firmware on it.
It runs pi4 with duet36hc and duet EXP 3 HC.
I thought i could just update firmware on dwc as I do on my other duet printers,
Did that now I am stuck with can't connect dcs has not started what have I done wrong and is this fixable without loosing all the configs? -
@caveman log in via SSH and run
sudo apt update && sudo apt upgrade -y
That should be the way you upgrade the firmware as it handles all the pi stuff and upgrading all the boards.IIRC, the files are held in
/opt/dsf/sd
