Troodon 400 bltouch trouble
I had the same issue when upgrading to firmware 3.0 and the solution is really easy I downloaded the attached 2 files for deploy probe and retract prob from Robert Luciano link below and everything worked perfect.
@bubblehead Hi, i have the exact same hotend and machine, and am now having the same issue. I then upgraded to 3.0 and would like to revert back to factory firmware - where did you get the original firmware? Can you supply a link please. Thank You!
