Strange Behavior , after "Pause" 'Cancel ""print again"
I just noticed in your pack of files that cancel.g has a leading blank space character.
@moth4017 said in Strange Behavior , after "Pause" 'Cancel ""print again":
Did "Print again" after cancel
Cancelled printing file 0:/gcodes/Body1_0.2mm_ABS__9h28m.gcode, print time was 0h 1m
Error: Failed to home axesDo you have a start.g file? If not, can you create one and add G28 to it?
That should make sure all axis are homed before the sliced gcode is executed.I think the over temperature warnings on drivers 0.4 and 0.5 may be related to stall detection on the Z axis.
@phaedrux
Will do ill test now so you have results in the morning -
@phaedrux
Interesting after removing the "space " from the "cancel.g" file the commands now work
also the over temperture errors seem to have stopped, will do more checks to confirm -
After testing , I can confirm all the above issues are caused by the space in front of the " Cancel.g" file , including the errors below.
Thanks for the help. im guessing you will want to trap this issue some how, help happy to help test if needed .
Cancelled printing file 0:/gcodes/Body1_0.35mm_PLA__17m.gcode, print time was 0h 0m
Error: Probe was not triggered during probing move
Error: Driver 0.4 error: over temperature shutdown
Error: Driver 0.5 error: over temperature shutdown
Error: Driver 0.6 error: over temperature shutdown
Error: Driver 0.4 error: over temperature shutdown -
Well I think what's happening here is that with the cancel.g basically missing when the print is canceled it's getting sent M0
https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m0-stop-or-unconditional-stop
Then when trying to print again the machine is not in a ready state. When the motors are in stealthchop mode they require a short tuning move and I guess that's not happening, hence the errors.
It would be best to have a cancel.g and stop.g file present with the commands you wish to happen. Use M0 as your slicer end gcode, then have all your ending commands in stop.g.
You can also use a start.g file that has any preparation commands you want. Like homing the printer, pre-heating, etc.
That should give you more predictable behaviour.
@phaedrux
Thank you for the advice, please close thiis thread -
