Installing duet 3d on stratasys fortus 350 mc machine
@vaibhav123 said in Installing duet 3d on stratasys fortus 350 mc machine:
there is no gear box it is direct with four pulleys for x axis at each corner and 2 for y axis
OK, so it does not really need the very high speed motors to work, just the torque.
It should be possible for it to work with NEMA34 steppers that can be driven direct from a high current Duet board, or using those with external drivers / the existing motors with the Leadshine BLDC drivers, with a Duet that can output step and direction.
