Precision Piezo z probes guide for duet users reference
This post is deleted! -
Hey, again. The piezo was working fine for several builds / hours, but then one day suddenly reverted to being overly sensitive again. I checked that the resistance measurements on both trimpots hadn't changed, and then went back as I had previously done to dial back the sensitivity.
That worked for a few days, but then the oddity occurred again, but this time it suddenly became very insensitive. In both cases, I know of nothing that would have caused the changes. Both times, I was printing fine the day before, and when I went to start a print the next day, the problems were immediately there. There's been no change in the mount, possible disturbances or damage to the printer, no one has touched it, etc.
It seems as though there might be a cracked or poor solder connection somewhere. As I had posted earlier in this thread (14 March), I've never measured 10K from VR1 to a negative connection - always 0.5 or less. No one commented on that, so perhaps that's not an issue.
Any ideas?
I'll get Idris to chime in on this one.
@plasticmetal said in Precision Piezo z probes guide for duet users reference:
That's very odd behaviour, it suggests that VR1 is occasionally going open circuit. Are you able to measure the resistance between PZ+ and PZ- while turning VR1 (gently) from one end of it's travel to the other?
Can you drop me a PM or a message on the website with your order number, I may need to send you a replacement.
Idris
@moriquendi said in
I've sent a message via your website. Thanks!
Hi @DjDemonD ,
I have recently installed an Orion on my Kossel XL and would like to make a modified version of the groovemount part. Is it possible to obtain the STL for that please? Even better would be an scad file if that's available.
Thanks,
Mark
Is anyone alive at Precision? I replied on the 17th to an email from Idris for troubleshooting, and haven't heard anything since. I replied again on the 20th and yesterday, and still no word.
Hi I'll give Idris a nudge. Sorry you haven't heard from us since then.
@plasticmetal What email address did you use? I can't find any emails I've not responded to. Failing that try sending a message through the website.
Idris
Thanks to both of you for replying. I don't see a way to PM through this forum, so I'll reply here.
Following my question earlier in this thread, I initiated contact through your website, and received a reply from Idris on the 17th. This was from reply at crm . wix .com. I replied through that email, which had a "reply to" field of eaQ0....TtA at the same domain.
All three of my reply attempts have been to that same email. I've checked the spam inbox, and there aren't any messages there (and as the first email came through fine, I wouldn't expect later ones to get flagged).
Thanks for trying to get this resolved.
I suspect something has gone wrong with the reply address somewhere. If you'd like to send an email to precisionpiezo at yahoo dot com hopefully that'll come straight through.
Idris
Thanks, just sent via yahoo.
Hi
I have installed the Orion piezo and it works . When performing G29, the first 6 point are probed, then it will always trigger before probing at 1 specific point on the bed (left,back, point number 7)....I think this has to do with some more movement due to the cable at that point...is it possible to pause a bit in G29 before probing, to let it stabilize...couldn't find a parameter for that. When doing G30 at the problem x,y point it always probes correctly -
BTW I have this in config.g
M558 P5 I1 R0.9 F120 X0 Y0 Z1 T3000ยจ ;Piezo
G31 X0 Y0 Z-0.1 P100 ;piezo -
It seem sthat M558 R0.9 (before 0.4) works
Description of M558 is confusing
"Z probe recovery time after triggering, default zero " I think it means before probing not after triggering. Or? -
So R is a pause before probing. Use around 0.4 seconds, some points on the bed might false trigger if your bowden cable goes tight.
I have an Orion on a new build (not in service yet). I'm using this in config.g:
;Precision Piezo Orion
M558 P8 I1 H5 R0.5 F150
G31 X0 Y0 Z-0.05 P600Last night I finally got the Orion wired and was able to home Z with it several times... all was well. This afternoon I came back to it, and it crashed the bed (not bad, I have the speed fairly slow and was able to kill it quickly). I discovered that the blue LED (trigger) is constantly lit. What can cause this?
Thanks!
I would check the calibration potentiometer. Adjust it as per the documentation. It is a good idea to make this adjustment, at the temperatures you would normally use when probing the bed. So if thats with heaters off, calibrate with heaters off and vice versa. Piezos do change sensitivity when heated or cooled, its a very sensitive instrument.
I am having trouble getting my new peizo to trigger using G30, it works when I run homez.g but when I run G30 it just crashes into the bed.
Is the issue with my M558 line?
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool on Sat Jul 21 2018 13:51:16 GMT+1200 (New Zealand Standard Time) G91 ; relative positioning G1 Z5 F6000 S2 ; lift Z relative to current position G1 S1 Z-295 F1800 ; move Z down until the switch triggers G92 Z2.5 ; set Z position to trigger height ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 S2 ; lift Z relative to current position ;G90 ; absolute positioning
From config.g
; Z-Probe ;M558 P0 H5 F420 T6000 ; Set Z probe type to switch and the dive height + speeds G31 X0 Y0 Z-0.1 P600 ; Set Z probe trigger value, offset and trigger height M557 X15:305 Y15:285 S20 ; Define mesh grid M558 P8 H5 I1 R0.4 F1800 X0 Y0 Z0
