HEVO triple kinematic bed configuration
@dingo007 measure at the pivot point, i.e. the ball studs.
so the ball stud locations should go in M671
the M671 order should be the same order as the motors are defined in M584
so Z0.0:0.1:0.2 and M671 should be the location for the ball studs in that order -
ok and this is compared to the machine home position X0Y0 including the probe offset ?? so im measuring from that point to the pivots i take it.
@dingo007 yep
The measurement doesn't need to be 100% exact to work either. The closer the better, but don't fret over half a mm.
