BLTouch stuck at 1000
@wieman01 I haven't changed them since i first got them working, but sure, let me pull them up
M280 P0 S10 I1; deploy BLTouch
M280 P0 S90 I1; retract BLTouch
@messiahman said in BLTouch stuck at 1000:
I1
Remove those as they aren't used in RRF3 to invert. That's done in the pin definition now. Though it won't stop it from working.
I think you have a cabling issue. Can you show a photo of where the wires are plugged in both at the board and the probe? Can you test connecting the probe directly to the board with it's short pig tail wires to remove your extension wires from the equation?
Also let us know what BL version you have got. Depending upon the version you may need different cabling (including a resistor, etc.). You find the version number on the back of the device.
