Swaping Autotune Parameters
I need to call different autotune values depending on if my printers enclosure is open or closed, otherwise I receive a heater fault. I am thinking about saving the M307 values in two macro's then running the one that applies before a print. Is this the best way of doing it?
If you could fit a switch to sense when the enclosure is open or closed you could have the M307 values change based on the state of the switch.
@fcwilt That's a good idea, thanks for the suggestion. I forget there is I/O.
