DWC 3.3.0-rc1 HeightMap / Temperature graph not showing
@jay_s_uk RepRapFirmware height map file v2 generated at 2021-11-10 11:13, min error -0.377, max error 0.880, mean 0.136, deviation 0.386
axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
X,Y,10.00,290.00,20.00,180.00,-1.00,40.00,40.00,8,5
-0.368, -0.330, -0.166, -0.087, 0.120, 0.318, 0.577, 0.849
-0.377, -0.267, -0.203, -0.083, 0.218, 0.288, 0.539, 0.790
-0.309, -0.236, -0.142, -0.103, 0.078, 0.328, 0.569, 0.827
-0.222, -0.246, -0.188, -0.062, 0.114, 0.374, 0.631, 0.880
-0.128, -0.201, -0.206, 0.011, 0.178, 0.351, 0.541, 0.798 -
@jay_s_uk
" Can you try deleting the dwc-settings, dwc2settings and dwc-plugins json files in the sys folder? "
Could only find dwc-settings.json and dwc2 settings.json; no dwc-plugins file. -
@robins3 thats fine, it may not have been created if you haven't used any plugins.
I've tested your heightmap on one of my machines running DWC 3.3.0 and it displays correctly
what browser are you using? -
@jay_s_uk Firefox version 94.0.1 (64 bit) it says it is up to date
@robins3 did deleting those files make a difference?
can you also test another browser? -
@jay_s_uk deleted files and rebooted, no difference
stopped the toolchanger and rebooted, no differencethe dwc settings files have not re-established themselves
I am unable to change browser at this moment.
@jay_s_uk
OK, grabbed another terminal , loaded Edge browser.Temperature graph and height map both showing.
I am running standard Firefox, with no extensions that ought to interrupt DWC
(Dragon and Google opt out) -
@robins3 must be something firefox doesn't like.
one for @chrishamm to comment on -
@jay_s_uk Thanks for the assistance, at least it isn't me this time!
@jay_s_uk @robinS3 I doubt that, I've been using Firefox for DWC development and I have never had problems with the temp charts or height map controls. Perhaps 2D/3D components are disabled in the Firefox config.
In Firefox press F12 to open the dev tools and check the JS console for error messages.
