Duet 2 wifi - Z axis doesnt double-home, wifi constantly drops
Hey Everyone, I have a Makergear M2 that I just converted to work with a Duet 2 wifi. I am well versed in Marlin and my printers original Rambo board, but Duet is all new to me. My main issues are:
x and y home quickly and then do a second pass at a much slower speed for accuracy. Z does not do this and essentially slams into the sensor and stops. I believe that this is introducing inaccuracy in the home position because i had to add almost an extra mm to the z offset to get the nozzle to clear (I home at Z max). Also when I home, I have to move the bed up 1 mm to hear the micro switch click.
The wifi is CONSTANTLY dropping connection. I have the duet with the internal antenna, and my signal is around 59-61. I'm considering just trying to use my canvas (octoprint) hub just so I can avoid the constant, and often really badly timed, wifi interruptions.
Any help would be awesome with these issues. Very excited to get printing again using the Duet, as the motors are 1000x quieter with the new board!
Jeremy
First thing people are going to ask is:
- Post your config.g and config-override.g using the "Code" button at the upper-level of the posting editor.
- Post all of your homing files homex, homey, homez, homeall (Of course using the "code" button)
- Post the results of M115 using the "Code" button.
- Post the results of M122 using the "Code" button.
This will help people know where you are at with settings and can increase the odds they will be able to get you running better.
Thanks @alankilian here is the info you mentioned:
Config.g
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.5 on Sun Nov 07 2021 17:10:06 GMT-0700 (Mountain Standard Time); General preferences
M550 P"Makergear M2" ; set printer name; Network
M551 P"**********" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X88.89 Y88.89 Z1011.90 E430.00 ; set steps per mm
M566 X900.00 Y900.00 Z24.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z1500.00 E1500.00 ; set maximum speeds (mm/min)
M201 X800.00 Y800.00 Z200.00 E10000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y255 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M558 P0 H0 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:190 Y15:235 S20 ; define mesh grid; Heaters
M143 H0 S130 ; set temperature limit for heater 0 to 130C
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M143 H1 S400 ; set temperature limit for heater 1 to 400C; Fans
M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 D0 H1 F1:0 ; define tool 0
G10 P0 X-3 Y4 Z-4.75 ; set tool 0 axis offsets
T0 ; select first toolConfig-override.g
; config-override.g file generated in response to M500 at 2021-11-07 16:06
; Heater model parameters
M307 H0 R0.206 C727.664:727.664 D16.27 S1.00 V23.7 B0 I0
M307 H1 R2.186 C278.525:278.525 D6.39 S1.00 V23.8 B0 I0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00homeall
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z0 F6000 ; lift Z relative to current position
G1 H1 X-235 Y-260 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-260 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z205 F360 ; move Z up stopping at the endstop
G90 ; absolute positioning
G92 Z200 ; set Z position to axis maximum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z0 F100 ; lift Z relative to current position
;G90 ; absolute positioninghomex
; homex.g
; called to home the X axis
G1 H1 X-235 F3600 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z0 F6000 ; lower Z again
G90 ; absolute positioninghomey
; homey.g
; called to home the Y axis
G1 H1 Y-260 F3600 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y-260 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioninghomez
; homez.g
; called to home the Z axis
G1 H1 Z205 F3600 ; move Z up until the endstop is triggered
;G90 ; absolute positioningM115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
M122
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MSJ-6JTD4-3S06Q-99PRB
Used output buffers: 3 of 24 (11 max)
Static ram: 23876
Dynamic ram: 75196 of which 0 recycled
Never used RAM 15344, free system stack 150 words
Tasks: NETWORK(ready,11.6%,237) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,321) MAIN(running,85.3%,445) IDLE(ready,2.9%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:32 ago, cause: power up
Last software reset at 2021-11-07 19:45, reason: User, GCodes spinning, available RAM 15344, slot 1
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 18.6, current 23.1, max 23.4
Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 4807, standstill, SG min/max 0/64
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-11-07 20:22:08
Cache data hit count 1189597590
Slowest loop: 25.57ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.1ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 341ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 1, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.64ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 60:01:94:2e:9e:75
WiFi Vcc 3.28, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25816
WiFi IP address 192.168.1.79
WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
I have in the past had wifi issues like you describe after doing an update or reverting to an older release. I think sometimes the wifi firmware gets messed up. Try reflashing it by running
M997 S3
from the console and when that completes, switch the power off and on again.
It might take flashing a couple of times but this should work. -
@ajdtreyd thank you
I noticed that it seems to drop connection with my octopi at the same time as it drops the wifi connection. The octopi throws a message that says the printer experienced an error and dropped the connection. I dont know if the duet it breaking the connection, or just glitching or restarting
If you compare homez to homex or homey, the other axes have two moves defined and Z only a single one.
Try changing the homez and Z section in homeall something like this. with the fast - back off - slow sequence of moves:
homez ; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.5 on Sun Nov 07 2021 17:10:06 GMT-0700 (Mountain Standard Time) G91 ; relative positioning G1 H2 Z0 F6000 ; lift Z relative to current position G1 H1 Z205 F3600 ; move Z up until the endstop is triggered (First pass) G1 H2 Z-5 F6000 ; go back a few mm G1 H1 Z205 F360 ; move slowly to Z axis endstop once more (second pass) G92 Z200 ; set Z position to axis maximum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z0 F100 ; lift Z relative to current position ;G90 ; absolute positioning
@rjenkinsgb I briefly tried that last night but I didn’t restart the printer afterwards. Does the board need a restart for changes to the homing files like it does for the config.g? Or are they essentially just macros that read from the hone files as they are used?
Jeremy
@wrenches they're just macros that are read when they're used.
Post the changes you've made to your files and we can comment on them -
@jay_s_uk the changes I made were after the files I posted, but I will post them when I get home from work tonight
@rjenkinsgb Heres what I put and it seems to work perfectly. Hopefully this will improve the repeatability of my z axis. Thanks for your input!
; homez.g
G1 H1 Z205 F3600 ; move quickly to X axis endstop and stop there (first pass)
G1 H1 Z10 F360 ; move slowly to X axis endstop once more (second pass)
;G90 ; absolute positioningAs for the wifi issue, I have done the in app firmware update the @ajdtreyd suggested, and we will see if I continue to have dropouts.
Thank you for your help everyone!
This post is deleted!
