how to configure magnetic filament sensor on duet 3 mini 5+
I have conected my rotating magnet sensor to IO_5 on Duet3 mini 5+ but I can't find out how to set up my config.g
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 16 2021 12:55:16 GMT+0200 (Centraleuropæisk sommertid); General preferences
M550 P"JK Preddy mod" ; set printer name
M665 R261 L440 B185 H420 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"^io1.in" ; configure active-high endstop for high end on X via pin ^io1.in
M574 Y2 S1 P"^io2.in" ; configure active-high endstop for high end on Y via pin ^io2.in
M574 Z2 S1 P"^io3.in" ; configure active-high endstop for high end on Z via pin ^io3.in; Z-Probe
M558 P5 R0.4 C"temp2+io4.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 R180 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
M106 P2 S0.25 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M591 P3 C"e0_stop" S1 ; filament monitor connected to E0_stop; Miscellaneous
T0 ; select first toolwhat am I missing?
@j3dk See https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Duet_Num_3 for connecting.
Change
C"e0_stop"
(which is Duet 2 pin name) toC"io[x].in"
where[x]
is the IO connector you have connected the sensor to.Ian
@droftarts Hi there thank you for the advise. now I have figured it out putting this line in my config.g it works
M591 D0.3 P3 C"^io5.in" S1 ; filament monitor connected to E0_stop -
@j3dk said in how to configure magnetic filament sensor on duet 3 mini 5+:
C"^io5.in"
You shouldn't need the
character in the pin name, it enables the pullup resistor.Ian
