True Bed Leveling G32
Hi
When i do repeated G32 True Bed Leveling i can see that it keeps repeating the same corrections by every G32.
Ex: I do a G32 and it measures every corner/leadscrew and when in the final phase and calibrating it lowers leadscrew 1 and rises leadscrew 3. Leadscrew 2 and 4 are quite consistent.
If I do the same procedure again it only repeats the same correction. I thought that if i did a G32 it did a correction so it didnt have to do the exact same correction again and again. And why is the correction of leadscrew 3 always close to 2-something.I dont get it...
Regards Helge
2021-9-10 22:56:58 G32
Leadscrew adjustments made: -0.573 -0.574 1.920 -0.694, points used 4, (mean, deviation) before (-0.026, 0.651) after (0.000, 0.000)2021-9-10 22:53:01 G32
Leadscrew adjustments made: -0.563 -0.580 1.909 -0.490, points used 4, (mean, deviation) before (0.026, 0.644) after (0.000, 0.000)2021-9-10 22:50:00 G32
Leadscrew adjustments made: -0.563 -0.616 2.873 -0.699, points used 4, (mean, deviation) before (0.187, 0.900) after (0.000, 0.000); bed.g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 30 2021 22:46:27 GMT+0200 (sentraleuropeisk sommertid)
;M561 ; clear any bed transform
;G29 ; probe the bed and enable compensation
G28 ; home
;M401 ; deploy Z probe (omit if using bltouch)
G30 P0 X700 Y400 Z-99999 ; probe near a leadscrew
G30 P1 X700 Y5 Z-99999 ; probe near a leadscrew
G30 P2 X5 Y5 Z-99999 ; probe near a leadscrew
G30 P3 X5 Y400 Z-99999 S4 ; probe near a leadscrew and calibrate 4 motors
;M402 ; retract probe (omit if using bltouch); Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 30 2021 22:46:27 GMT+0200 (sentraleuropeisk sommertid); General preferences
M550 P"Voron24" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; z drive 1
M569 P2 S1 ; z drive 2
M569 P3 S0 ; z drive 3
M569 P4 S1 ; z drive 4
M569 P5 S1 ; a drive 5
M569 P6 S1 ; b drive 6
M569 P7 S0 ; ex drive 7
M584 X5 Y6 Z1:2:3:4 E7
M671 X815:815:-125:-125 Y500:-130:-130:500 S20 ; leadscrews at rear left, front middle and rear right
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X700 Y400 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P1 C"zprobe.in" H20 F2000 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P1000 X0 Y0 Z1.995 ; set Z probe trigger value, offset and trigger height
M557 X15:700 Y15:400 S80 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
The results suggest the Z steppers are not actually adjusting the bed or at least not by the correct amounts
Have you verified that if you command, say, a 100mm move in Z that it moves 100mm?
@fcwilt Hm. It seems like its adjusting the bed correct. Could it be that i might have a faulty stepper motor thats not doing its job properly by a mm or two, thats difficult to measure by eye.
@hsverre said in True Bed Leveling G32:
Did you verify Z movement as I asked about.
Have you run G32 many times to see if it ever gets better?
It's possible to setup a loop which runs a max number of times or until a certain result is obtained.
From my bed.g file:
while true ; run leveling pass ; --- probe near bed corners --- G30 P0 X-140 Y-90 Z-99999 ; LF G30 P1 X-140 Y90 Z-99999 ; LR G30 P2 X140 Y90 Z-99999 ; RR G30 P2 X140 Y-90 Z-99999 S3 ; RF ; check results - exit loop if results are good if move.calibration.initial.deviation < 0.02 break ; check pass limit - abort if pass limit reached if iterations = 5 M291 P"Bed Leveling Aborted" R"Pass Limit Reached" abort "Bed Leveling Aborted - Pass Limit Reached"
