Board started smoking during print
I was instructed to post here via the @duet3d Twitter. I was in the middle of a print and all of a sudden the SD card started smoking then the main processor started smoking . I killed the power immediately. Voltage in is 25VDC. 12 in to the fan jumper to power 12 volt fans. No blown fuses. 3.3VDC LED is off now. Any ideas? I guess check for shorts on components.
Then, can I get a replacement board through a warranty? Purchased from matterhackers on august 3rd 2021.
Thanks,
Andrew -
Photos of the carnage?
With everything disconnected from the board can you connect USB and see what LEDs light up?
@phaedrux
Only red led for 5V and usb are lit. Scorch mark on main chip and sd card slot. -
What is it mounted on? Is anything possibly shorting out on the back?
@andrewjl said in Board started smoking during print:
@phaedrux
Only red led for 5V and usb are lit. Scorch mark on main chip and sd card slot.Can you dismount and disconnect everything from the board?
@phaedrux. Acrylic sheet behind it. Nothing obvious to short out on or evidence of it.
@andrewjl-0 said in Board started smoking during print:
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux I already contacted matterhackers where I purchased the board from. They just got back to me today with a return label and they're sending me a new board
@andrewjl Please also email warranty@duet3d.com as above. Matterhackers won't be able to send you anything until we've authorized them, and we can't do that until you complete the form.
