Physical buttons to run macros using duex5 with RRF3.3
Hello.
I've been looking at several posts related to duex5 pin names, in addition to documentation, and I'm having a hard time knowing how to use other duex5 pins besides extruder endstops (duex.e2stop to duex.e6stop). Are there any other pins I can use? How to know their name in the RRF3.3 object model?
I just built a voron 2.4 and I use duet2 wifi + duex5. I need more pins available, which can be duet or duex. Can anyone help me list all available pins? I want to make a panel of buttons to activate them and execute triggers.
Thanks.PS. Sorry for the google translation
@rodrigormaraujo
there's a hardware description image which names all the pins.
On the expansion port are several heater or endstop pins you can use for external switches and push buttons. -
@o_lampe Thanks for answering. I can't use the expansion connector because I have a duex5 attached. I also don't have the knowledge to understand which pins can be used. I am learning...
