Duet 2 WiFi | 3.2.2 to 3.3 Stuck
So on my Rostock Max V4 I upgraded the firmware to RRF 3.2.2 with no problems, things were working fine. In my mind, I thought it would be completely fine to upgrade to 3.3. So I sent the M997 S3.3 command and it upgraded. The duet would no longer connect to my WiFi Network.
I've tried messing with starting, stopping, resetting, trying to reload 3.2.2, etc.
I am now stumped and out of ideas, I feel it can't be too complicated, when I send M115 I get a RRF3.3 and Duet Wifi 1.02.
I feel like it is an incompatible version of the wifi file with the new /firmware folder within 3.3 (different than /sys in 3.2.2), but I do not know.
Is there a way I can just go back to 3.0 clean slate? Then I'll upgrade to 3.2.2.
Let me know what would be the best course of action.
M122 Command:
M115 Command:
@jordan_miller41 said in Duet 2 WiFi | 3.2.2 to 3.3 Stuck:
Occasionally the wifi module firmware update will fail silently and the module won't work until the firmware is reapplied.
Please try sending M997 S1 to reflash the wifi module.
https://duet3d.dozuki.com/Wiki/FAQ#Section_Cannot_start_wifi_after_a_firmware_update
@jordan_miller41 would you mind sharing your gcode configs? I have the same printer and it's completely broken after upgrading the firmware. I have fixed a lot of things but I currently am stuck with "no tools" configured/detected and I cannot figure out how to get past this.
@daveman1010220 Probably a good idea to start a new thread with the details of your issue so we can help you out.
@phaedrux Download and load 3.2.2 onto the SD card? Then send the M997 S1 command? Or do 3.3 and send command?
The wifi firmware file should already be there either from 3.2.2 or 3.3, it doesn't matter at this point which. M997 S1 will try and use whichever version is present. Once it's flashed the module should start working again and then you can check what version is installed with M122 and update it if need be.
@phaedrux M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SJ-6J9F2-3S06M-1AWHD
Used output buffers: 3 of 24 (10 max)
Static ram: 23876
Dynamic ram: 74876 of which 0 recycled
Never used RAM 15664, free system stack 134 words
Tasks: NETWORK(ready,19.9%,143) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,305) MAIN(running,78.6%,441) IDLE(ready,1.4%,29), total 100.0%
Owned mutexes:
Last reset 00:01:07 ago, cause: software
Last software reset time unknown, reason: User, GCodes spinning, available RAM 15664, slot 0
Error status: 0x08
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 23.0, current 24.1, max 24.3
Supply voltage: min 13.5, current 13.6, max 13.9, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 129859, standstill, SG min/max 0/377
Driver 1: position 129859, standstill, SG min/max 0/1023
Driver 2: position 129859, standstill, SG min/max 0/379
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-08-09 18:47:50
Cache data hit count 2612550386
Slowest loop: 5.96ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.8ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 41048ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 8, completed moves 8, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1510.93ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address ec:fa:bc:25:b8:32
WiFi Vcc 3.43, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24960
WiFi IP address 192.168.68.69
WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Looks to be working now, thank you so much!
- WiFi -
Looks like it used the previous wifi firmware from 3.2.2
To ensure you;ve got everything in the right place, upload this zip file once more to the system tab. It should update the wifi firmware this time to 1.26.
Then you can remove all of the bin files from the system tab if you wish to tidy it up. All the firmware bin files are now located in the firmware folder. You can see them by clicking on the little drop down at the top of the file list, I think by default it says "system files" and you can click on it and choose "firmware files".
@phaedrux Ok, should I take the SD out and move this file into the /firmware folder I created?
More than that you can move all of the .bin files from the system folder into the firmware folder so that all the IAP files are there as well.
But if you still have access to dwc uploading that full zip file should do it already.
Can you check your DWC version to make sure it's 3.3?
