Duet2 wifi do not connect with USB
I can't reach Duet2 wifi harware even with USB. Wifi is not responding so I tried with USB.
But USB port is not available on PC. YAT or SerialTools do not recognize Duet.I tried to erase firmware to re-install. But nothing is responding when erase with jumper.
3.3v LED is not running only 5v is lighting.
Could you help?
Best regards
Eric -
Do the LEDs that light up change when you apply VIN power?
Can you provide a higher resolution photo of the board in case we can see a failed component?
Otherwise, please try working through this page https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
