PWM to 10V via e0heater always gives 10V
@cjm I agree, from the photo it appears that it has an opto isolator for the input. So why is there continuity between the PWM input ground and the output ground?
@larsw I tried to use a similar type for an older CNC controller of mine and didn't have any luck. I eventually found and used this type which worked:
Available from the usual places. -
As a side note, this board reminds me of a similar project by egon.net https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
@cjm I tried the pull resistor (4.7k) and it worked perfectly.
Only issue now is, that the 0-10V output max'es out at 8.6V, but I read somewhare that the converter - even though the specs says VIN 12V to 24V needs least 14,6V to reach 10V in output signal, and my powersupply is 12,8V.
8,6V is close enough - my spindle reaches to max speed at 9V.
@alankilian they've made a mistake with that design IMO, by sharing the ground plane with both ground pins even though the input is optically isolated.
I would be tempted to cut the 4 fingers that join each of the pins I have marked to the ground plane, and connect them together with a wire instead.
@larsw said in PWM to 10V via e0heater always gives 10V:
That's GREAT news!
Thanks for keeping up with our ideas and letting us know you got it working.
If you want to get to 9 Volts, you can try adjusting the potentiometer on the board.
@larsw Good news! Glad to hear it’s all working now…
@alankilian said in PWM to 10V via e0heater always gives 10V:
I hope somebody else can use these findings. The converter seems to be pretty common.
This is with the potentioneter at max, but as I said - good enough.
@educatingsavvas
I just wired up one of these and it works too.One thing to note is that using less than 3000hz seems to result in the generation of a 0-10v signal that the VFD sees as oscillating and then it changes frequencies a lot. It ramps up and down 10’s of hertz.
