Duet Web Control Stuck On "Disconnected"
Hello ive been using this printer for months now without issue. Then randomly yesterday I stopped being able to connect via the web interface. It loads up and shows the typical GUI but the status on the top left is a grey "disconnected" and all the buttons dont work. Ive tried power cycles, trying on different browsers, trying on different devices, and nothing works. Im not sure how to proceed from here. I havent tried to connect via USB due to it being in a difficult location, but if I have to then I can get some long USB cables.
Yes you'll need some access to the board to figure out what's going on. All we can tell right now is that DWC is not able to reach the board.
Once you can see the board check what LED lights are lit up.
What Duet board is it?
Ethernet or wifi?
When you have USB connected see if you can reach it via YAT usb terminal to see if it's responding.
You can also check the SD card in a PC to see if it's still working. -
@phaedrux I reinstalled the files on the SD card and that seems to have fixed the issue. Not sure what was wrong with the card. Thank you.
