Need help with Ender-6 core xy motor movement
;FLAVOR:RepRap ;TIME:388 ;Filament used: 0.145903m ;Layer height: 0.2 ;MINX:67.247 ;MINY:108.91 ;MINZ:0.2 ;MAXX:182.753 ;MAXY:141.085 ;MAXZ:0.8 ;Generated with Cura_SteamEngine 4.10.0 T0 M190 S50 M104 S200 M109 S200 M82 ;absolute extrusion mode M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk M220 S100 ;Reset Feedrate M221 S100 ;Reset Flowrate
You're ok for reprap flavor.
And as expected, these lines are causing the speeds to be slow.
Delete them from your start gcode.
I removed the starting gcode info and the print was much faster.
Thanks for that!Regarding the probe calibration.
I had run that previously.
But, I ran it again anyway.
Even after running it again, I had to babystep +0.6mm to get filament to flow.Is there someway to make the baby steps permanent?
I have to adjust for every print. -
@davidewen said in Need help with Ender-6 core xy motor movement:
If you constantly need to baby step up 0.6mm then you can simply modify your G31 Z value to take that into account. That's how you make it permanent.
It could also be that you are homing Z at a different location than where you are measuring the offset. Ideally they should be the same location at the center of the bed.
I have the config.g file G31 Z value set, but I still have to adjust each print.
I'm still printing the test "DUET" text. Same gcode, just rerunning it.
I understand, but if you're consistently needing to babystep, then you can modify your measured G31 Z with that baby stepping amount to make it permanent. Consider it a fine tuning of your G31 Z offset.
If you have G31 Z2 and you have to add +0.6mm to get a good first layer because your nozzle is too close after homing with the probe you can take 2mm - 0.6mm = 1.4mm and change to G31 Z1.4
That seems to have done the trick.
Thanks again.One more thing I'm having trouble finding info on.
When the print is done, the X/Y carriage moves.
In my case towards the front of the printer.
I would like to move it towards the back of the printer. -
That would all be controlled by your slicer end gcode.
