Problem About Bltouch and Duet Wifi
Hi I bought a Duet Wifi board and 3D touch probe. I am trying to to configure it and couldn't manage to do it. I am using a reprap version 3.2.3. The problem is it blinks and sweeps several time then I send the gcode but it doesn't respond to it . I will be giving my config deploy and retract probe codes. I don't have any override file Thanks for Help.
My config code:
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X160.00 Y160.00 Z1600.00 E400.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X435 Y410 Z410 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z
G31 P25 X-26 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M950 S0 C"exp.heater7" ; create servo pin 5 for BLTouch
M557 X30:410 Y15:400 S20
M558 C"zprobe.in" P9 H10 F800 T2000
; Disable the 7th Heater to free up PWM channel 5 on the Duex board; set Z probe type to bltouch and the dive height + speeds ; define mesh grid
M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
M143 H1 S500 ; set temperature limit for heater 1 to 500C; Fans
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
My deployprobe.g
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 06 2021 14:27:02 GMT+0300 (GMT+03:00)
M280 P7 S10; deploy BLTouch
my retractprobe.g
; retractprobe.g
; called to retract a physical Z probe
M280 P7 S90 ; retract BLTouch -
@seymen said in Problem About Bltouch and Duet Wifi:
M280 P7 S10
you've set the servo channel up as S0 in your config but you're telling the deploy and retract to use the servo number 7.
Change the P7 to P0 on both deploy and retract.Then test the probe using M401 and M402
Thanks for your reply I am using heater 7 as my pin so i think I should change servo pin but I don't know where it is mentioned.
@seymen thats not how RRF3 works
Ok but As far as I know it's extruders pin. So wouldnt it make a problem ?
No.
My deployprobe.g ; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 06 2021 14:27:02 GMT+0300 (GMT+03:00) M280 P7 S10 ; deploy BLTouch my retractprobe.g ; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 06 2021 14:27:02 GMT+0300 (GMT+03:00) M280 P7 S90 ; retract BLTouch
Change P7 to P0
