Power required
Hi everyone., I am making a cartesian printer to run on duet2 wifi. all drives run by an 8mm lead screw. 400mm steps/mm. I just want to make sure if i buy a 24V25A-600W power supply is enough to run the printer? the power consumption details
Hot bed-240-260W-24V 260W
Hot end-40W 40W
Stepper-1.7A*2.8V-5nos-25W 25W
Fans-50W 50W
Total 375W
Extra-20% Total Power 75W
Total Power required 450W -
@sarvan, that will be fine. You forgot about the motion controller itself but you will still be fine with a 600W supply. Make sure it is a brand name such as Meanwell and that it is te real thing and not a knock-off.
@jens55 thanks Man
thanks guys
