Home Y not reading all lines of code
Hi All,
I hope you can help,
Trying to work out my homing issues. for my Y axis It doesn't seem to be reading the H1 code. It seems to be jumping straight to the move a few mm line. can some help?
G91 ; relative positioning
G1 H2 Z-5 F6000 ; lift Z relative to current position
G1 H1 Y235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y-5 F6000 ; go back a few mm
G1 H1 Y235 F360 ; move slowly to Y axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioningThis is my homey.G
@prior123 I suggest checking your endstops are working as intended using M119
@jay_s_uk said in Home Y not reading all lines of code:
M119
Hey, so you were right the Y end stop was properly connected (facepalm) however it that is now fixed but is still giving me the same outcome
That behavior suggests that the endstop is triggered when it should not be.
So the first move never happens because a G1 H1 stops when the endstop is triggered.
The second move happens because it is not a G1 H1 move.
The third move never happens because a G1 H1 stops when the endstop is triggered.
