Solved wifi not connecting
hi, so i have been trying to connect to my dwc and whenever i turn my printer on the wifi blue light will blink once but then never again, i can connect to it via yat but it was giving me error messages i cant remember what it said but then i read somewere that the firmware could be old which it was so i unhooked the sd card and added the new firmware to the card. now i am basically re going thru the adding a network process and when i run m587 with my network it tells me "failed to add ssid, error retrieving wifi status, bad reply format version. i have no idea what this means and idk why the wifi is just suddenly not working it was fine 3 days ago and now nothing is working. plz help. did i add the firmware wrong? is ther some way to check if the wifi module is working? i figured because the light flashed means its not broken but i know when its connected it constantly blinks or stays on idk but i know as soon as i turn it on if it works or not by that light blinking.
Please connect via YAT and send M122 and copy and paste the reply here. That will give us some more information.
Ideally we need to know what firmware version is on the Duet and then ensure the wifi firmware version is compatible.
This post is deleted! -
@phaedrux === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-9T6BU-FG3SJ-6JTD4-3S86K-TAXZF<LF>Used output buffers: 1 of 24 (1 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93140 of which 0 recycled<LF>Exception stack ram used: 244<LF>Never used ram: 11976<LF>Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:55 ago, cause: software<LF>Last software reset time unknown, reason: Heat task stuck, spinning module Platform, available RAM 11560 bytes (slot 1)<LF>Software reset code 0x00a0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x2000495c Task 0x4e49414d<LF>Stack: 0044d797 00445546 6100f000 00000000 000004d9 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f baa06630 3e3a3325 3e638e29 3e924925 35c8ffca 397d66d2 c0a00000 00000000 60000010 20003258 20008a10 0044d797<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
@zshoe said in wifi not connecting:
Can you make a change to the YAT settings so we can see the full thing with formatting?
@phaedrux m122
Static ram: 25712
Exception stack ram used: 256
Never used ram: 11964
Tasks: NETWORK(ready,1268) HEAT(blocked,1232) MAIN(running,3836) IDLE(ready,160)
Owned mutexes:
Last reset 00:02:51 ago, cause: power up
Error status: 0
MCU temperature: min 24.1, current 30.3, max 30.4
Supply voltage: min 0.1, current 1.5, max 1.5, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 272106402
Slowest loop: 1.07ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "m122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1.25ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi module is idle
WiFi firmware version 1.23
WiFi MAC address 60:01:94:2e:a9:0a
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 27920
ok
- WiFi -
Ok thanks that shows that your duet firmware and wifi firmware are matched up.
It would help to know what errors you actually get.
Send these commands and report back with what they return.
M552
M552 S-1
M552 S0
M552 S1
M587
Then try clearing any saved networks with
M588 S"*"
Then try adding your network again with M587 and enable the module again with M552 S1.
record any error messages.
@phaedrux everything works as it should up untill i runn m552 s1 and then i get "wifi reported error, no networks found, wifi module is idle" and then it just repeats that over and over. i run m587 and i get this
m587
Remembered networks:
TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
Shoemaker IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok
WiFi reported error: no known networks found
WiFi module is idle
WiFi module is idleit looks like it remembers my network but the ip is all blank which doesnt make sense to me.
@phaedrux m588 s"*"
M588: Failed to reset the WiFi module to factory settings
ok
Error retrieving WiFi status message: bad reply format version
WiFi module is idlethis is what i get when i try to reset it.
@phaedrux m587 S"Shoemaker" P""
M587: Failed to add SSID to remembered list
ok
WiFi module is idlei blocked out my password but i entered it in and i got this whenever i try to add my network again
Can you try sending M997 S1 to reflash the module?
@phaedrux WiFi module is idle
m997 s1
M997: File DuetWiFiServer.bin not found
ok -
@zshoe that made me check something because i remembered that file being added specifically so i went back and pulled the sd card and now i see that theres a lot of files in this "www" folder and in the file i got from here for the new firmware it had it all as individual files idk how that happened but could that be an issue? i just pulled all the individual files out of that folder inlcuding the one that m997 said was missing and put them on the main part of the sd card and im going to see if that did anything rn
@phaedrux M997: Firmware binary "Duet2CombinedFirmware.bin" not found
now i get this -
Can you post a screen shot of your folder layout?
There should be a /sys/ folder with your config.g and homing files and the firmware bin files.
There should also be a /www/ folder with some HTML files and a CSS folder etc.There shouldn't be anything but folders in the root of the card.
now i get thisTo do just the WiFi server you need m997 s1
@phaedrux you say those firmware bin files should be in the sys folder huh? maybe thats my issue
That is preventing us from flashing the firmwares anyway. Not sure it will help with the WiFi problem but reflashing is a good first step.
