wifi not connecting
Ok thanks that shows that your duet firmware and wifi firmware are matched up.
It would help to know what errors you actually get.
Send these commands and report back with what they return.
M552
M552 S-1
M552 S0
M552 S1
M587
Then try clearing any saved networks with
M588 S"*"
Then try adding your network again with M587 and enable the module again with M552 S1.
record any error messages.
@phaedrux everything works as it should up untill i runn m552 s1 and then i get "wifi reported error, no networks found, wifi module is idle" and then it just repeats that over and over. i run m587 and i get this
m587
Remembered networks:
TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
Shoemaker IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok
WiFi reported error: no known networks found
WiFi module is idle
WiFi module is idleit looks like it remembers my network but the ip is all blank which doesnt make sense to me.
@phaedrux m588 s"*"
M588: Failed to reset the WiFi module to factory settings
ok
Error retrieving WiFi status message: bad reply format version
WiFi module is idlethis is what i get when i try to reset it.
@phaedrux m587 S"Shoemaker" P""
M587: Failed to add SSID to remembered list
ok
WiFi module is idlei blocked out my password but i entered it in and i got this whenever i try to add my network again
Can you try sending M997 S1 to reflash the module?
@phaedrux WiFi module is idle
m997 s1
M997: File DuetWiFiServer.bin not found
ok -
@zshoe that made me check something because i remembered that file being added specifically so i went back and pulled the sd card and now i see that theres a lot of files in this "www" folder and in the file i got from here for the new firmware it had it all as individual files idk how that happened but could that be an issue? i just pulled all the individual files out of that folder inlcuding the one that m997 said was missing and put them on the main part of the sd card and im going to see if that did anything rn
@phaedrux M997: Firmware binary "Duet2CombinedFirmware.bin" not found
now i get this -
Can you post a screen shot of your folder layout?
There should be a /sys/ folder with your config.g and homing files and the firmware bin files.
There should also be a /www/ folder with some HTML files and a CSS folder etc.There shouldn't be anything but folders in the root of the card.
@zshoe said in wifi not connecting:
now i get thisTo do just the WiFi server you need m997 s1
@phaedrux you say those firmware bin files should be in the sys folder huh? maybe thats my issue
That is preventing us from flashing the firmwares anyway. Not sure it will help with the WiFi problem but reflashing is a good first step.
@phaedrux its still telling me duet wifi server.bin not found even tho i put it in the sys folder
when run m997 s1
@zshoe can you show a screenshot of the sys folder?
Download this zip file, extract it, and copy over the .bin files to the sys folder overwriting the ones that are there. Perhaps something has been corrupted.
@phaedrux so i ended up getting into a really bad car accident on the 28th at 230 omw to work or i would have tried this much earlier but it seems like that worked thank you all for the help i really appreciate it.
wow, glad you're ok and glad it fixed your issue.
