Z-axis up without homing macro
; cancel.g ; ; Run when the print is paused, and then canceled. ; G10 P0 R0 S0 ; Set hotend temp to 0 M140 S0 ; Set bed temp to 0 M106 S255 ; Fan at 100 to cool nozzle and bed M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M290 R0 S0 ; clear babystepping M204 P1000 T4000 ; Set printing and travel accelerations M566 X900 Y900 Z30 ; Set maximum instantaneous speed changes (mm/min) (Jerk) G28 XY ; home XY M98 P"0:/sys/CurrentsNormal.g" ; return motor currents to normal M98 P"0:/sys/ZSpeedsNormal.g" ; return Z axis speeds to normal M84 ; turn off steppers G4 S60 ; wait 1 minute for nozzle to cool M107 ; turn off the fan M98 P"0:/macros/Musical Tunes/TwoBits.g" ; play a tune
I suppose now with conditional gcode the homing at the start of a print could easily be made optional, so the logic of turning off the motors since I need to re-home anyway isn't as valid.
