Driver shutdown
Hi!
A few days ago, during a print, I saw a message on the Panel Due saying that Driver 8 (I have a Duex5) was shutdown because of overheating (or something like that).
But Driver 8 is unused, and has no motor connected! I only have a motor on the first channel of the Duex5...
Any idea what happenned ?
Have you tested if the driver works? Does it still produce the error? Was it actually hot at the time? What does M122 say about those drivers?
@phaedrux No, I didn't check this driver output; I'll do that.
The error did not reprodduce.
It was not hot at all (I checked only with my finger).
I'll run M122 tomorrow.Thanks.
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4S8-6JTDG-3SD6Q-13YRX Used output buffers: 3 of 24 (12 max) === RTOS === Static ram: 27980 Dynamic ram: 94292 of which 136 recycled Exception stack ram used: 472 Never used ram: 8192 Tasks: NETWORK(blocked,364) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1880) IDLE(ready,80) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:04:04 ago, cause: power up Last software reset at 2021-04-08 17:35, reason: User, spinning module GCodes, available RAM 8016 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 13.4, current 23.8, max 23.9 Supply voltage: min 23.4, current 23.7, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max 0/300 Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2021-04-18 08:49:10 Cache data hit count 405592994 Slowest loop: 6.09ms; fastest: 0.13ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.7ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 168, MaxWait: 32481ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 3, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.8 Heater 1 is on, I-accum = 0.2 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 41.09ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 5c:cf:7f:61:99:c5 WiFi Vcc 3.35, reset reason Unknown WiFi flash size 4194304, free heap 24432 WiFi IP address 192.168.0.3 WiFi signal strength -59dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === DueX === Read count 1, 0.25 reads/min
Mmm, now, over temperature shutdown is reported for driver 7!!!
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DDM-9FAM2-LW4S8-6JTDG-3SD6Q-13YRX Used output buffers: 3 of 24 (13 max) === RTOS === Static ram: 27980 Dynamic ram: 94564 of which 64 recycled Exception stack ram used: 584 Never used ram: 7880 Tasks: NETWORK(ready,368) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1848) IDLE(ready,80) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 05:22:57 ago, cause: power up Last software reset at 2021-04-08 17:35, reason: User, spinning module GCodes, available RAM 8016 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 14.2, current 37.1, max 38.0 Supply voltage: min 23.2, current 23.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: ok, SG min/max 0/413 Driver 1: ok, SG min/max 0/426 Driver 2: standstill, SG min/max 0/300 Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: ok, SG min/max 0/1023 Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Date/time: 2021-04-18 18:39:39 Cache data hit count 4294967295 Slowest loop: 311.40ms; fastest: 0.13ms I2C nak errors 0, send timeouts 27, receive timeouts 0, finishTimeouts 27, resets 27 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 45.4ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 163, MinFreeDm: 136, MaxWait: 7796464ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 207672, completed moves: 207641, StepErrors: 0, LaErrors: 0, Underruns: 0, 3 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.4 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X213.653 Y124.192 F9000.000" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 40.51ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 5c:cf:7f:61:99:c5 WiFi Vcc 3.34, reset reason Unknown WiFi flash size 4194304, free heap 24240 WiFi IP address 192.168.0.3 WiFi signal strength -59dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === DueX === Read count 39, 0.12 reads/min
and was driver 7 in use at the time?
@phaedrux Nope! Only Driver 5 is in use (first one on Duex5), for the hotend...
How driver status are reported? Could it be a wire problem in the cable between the 2 boards?
I'm not sure, but maybe this can be an issue from the flat cable
How is your duex wired up? Particularly the grounding?
Anything running near the ribbon cable?
https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
Boards are wired as described in the documentation. Nothing is near the ribbon cable.
But I'll check all connections...
