E 3d BIGBOX Duel head
@phaedrux i do have height map file but no mesh file?
RepRapFirmware height map file v2 generated at 2021-06-28 11:26, min error -0.544, max error 0.151, mean -0.065, deviation 0.281
xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
5.00,250.00,5.00,200.00,-1.00,40.00,40.00,7,5
0, 0, 0, 0, 0, 0, 0
0, 0, 0, 0, 0, 0, 0
0, 0, 0, 0, 0, 0, 0
0, 0, 0, 0, 0, 0, 0
0, 0, 0, 0.114, -0.544, 0.151, 0.018 -
@phaedrux would this have anything to do with my Z stepper motors being wired backwards on the duet board ?
How do you mean wired backwards?
If you're getting a lot of skipped points you'll have to adjust your grid range to take into account the Z probe XY offset. Due to that offset there will be parts of the bed that the nozzle can reach but the probe cannot.
35 points isn't a lot of detail. It can be very informative to do a high detail probing so that you can see what the topology of the bed actually looks like. You can use up to 441 points.
Instead of using M557 S40 which defines the spacing of 40mm, you can use P# which lets you define the number of points to use and it works out the spacing for you.
@phaedrux
ok went back over everything and got the bed compensation to work and i now have 99 points for bed leveling. so not bad i think.now onto calibration the extruder with the test files.
I know this is not right i have something backwards but i know the wiring is correct i have checked it twice. i also think the end stop for x is not working properly either due to bouncing but no sure.
@gauravdhaka you might have posted in wrong thread
@gauravdhaka Please start a new thread.
@phaedrux
ok very good board in and is printing, poorly right now but printing.
here is my files to the E3D Big Box with single head print for now. my config.g file. this works on my unaltered E3D big box printer with the Duel wifi board.; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue May 25 2021 18:51:26 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"big Print 1" ; set printer name
;M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X160.00 Y320.00 Z1600.00 E274.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E270.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X250 Y200 Z290 S0 ; set axis maxima; Endstops
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
;M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M558 P5 C"e0stop" H5 F120 T3000 ; Z probe connected to E0 endstop input
;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X33 Y26 Z1.5 ; set Z probe trigger value, offset and trigger height
M557 X15:250 Y15:200 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R160 S220 ; set initial tool 0 active and temp 240C and standby temperature to 160C; Custom settings are not defined
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossthank you for your help.
