SD Card Purge--how far?
How far can I go on purging my SD Card? In my Sys folder, I have my config, and two triggers. In my Macro folder, I have my two macros.
Can I delete everything else? Is there anything that needs to remain?
Thanks!
I asked this earlier and my Duet2/Ethernet running 3.2 I was supposed to keep all these files in the sys directory:
bed.g cancel.g config.g Duet2CombinedFirmware.bin dwc-settings.json homedelta.g iap.bin iap4e.bin pause.g resume.g tfree0.g tpost0.g tpost1.g tpre0.g tpre1.g config-override.g heightmap.csv config.g.bak iap4s.bin Duet2CombinedIAP.bin config.json sleep.g stop.g dwc2settings.json Duet2_SDiap32_WiFiEth.bin manifest.json.gz
I believe starting in 3.3 there will be a firmwares folder inside of the /sys folder that will take all of the firmware bin files etc.
Furthermore, eventually DWC will be smart enough to only upload the firmware files that are applicable to the board.
@alankilian Thanks!
But shouldn't we be able to delete the .bin files?
And if we do not use pause, resume or cancel, there is there a reason to keep those?
I guess I should just start deleting, and see what happens...
The bin files could be deleted but they are handy to have in place in case you need to reflash in an emergency. The IAP files are required to perform a flash.
