Wrong password while trying to connect to ?
I can't get my duet 3 mini 5 to connect to the network !!!
Tried with my normal router I use and got a "Wrong password while trying to connect to"
I had learned how to remove it with M588 S"*"
So I did a :-
M552 S0
M588 S"*"
M587 S"TP-LINK_2.4G" P"mypassword" or M587 S"TALK5" P"mypassword"
M552 S1and a M552 got
M552
SENDING:M552
WiFi module is changing mode
WiFi reported error: Wrong password while trying to connect to TALK5
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi reported error: Wrong password while trying to connect to TALK5m122
SENDING:M122
RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: MZSV6-S096U-D65J0-40KMD-3413Z-R7859
Used output buffers: 1 of 40 (14 max)
Static ram: 98732
Dynamic ram: 106576 of which 344 recycled
Never used RAM 39564, free system stack 140 words
Tasks: NETWORK(ready,360) HEAT(blocked,362) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,362) TMC(blocked,123) MAIN(running,439) IDLE(ready,20) AIN(blocked,269)
Owned mutexes: USB(MAIN)
Last reset 00:15:04 ago, cause: power up
Last software reset details not available
Error status: 0x00
[ERROR] Error status: 0x00Aux0 errors 0,0,0
Aux1 errors 0,0,0
Supply voltage: min 0.9, current 1.0, max 1.0, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Cache data hit count 2107016583
Slowest loop: 4.28ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.1ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.54ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is active
WiFi module is idle
WiFi firmware version 1.25
WiFi MAC address f0:08:d1:02:eb:a5
WiFi Vcc 3.42, reset reason Power up
WiFi flash size 2097152, free heap 29336
Clock register 00002002
=== CAN ===
Messages queued 4455, send timeouts 4455, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 167
FORGOT TO SAY -- the password is correct , via the router and connecting too it . My duet 2 is connected to that router ? , without problems ?.
- WiFi -
O.K , I've found the problem , but don't know if it is Pronterface ?
Say my password is "password1234" So I use M587 S"TP-LINK_2.4G" P"password1234" , But it sends M587 S"TP-LINK_2.4G" P"PASSWORD1234"
That's a known issue with pronterface and some other terminal programs. That's why we recommend using YAT or putting the M587 command in a macro and then executing the macro.
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
