no 3.3 v
just got my duex 5 today so i was doing some wire management when i turned back on i had no 3.3 power and no access over usb i unplugged everything and made sure my endstops fan heater etc werent crossed and it was good not sure what else do you think the board is fried somehow i still get 5v and vin
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
Photos of the wiring? If you disconnect the Duex does it work then?
I disconnected all the wiring and pulled it out to try and hook up to bossa but I didn't even get to hook up the duex yet I just was cleaning up some wiring getting ready to and turned it on that's when I noticed no wifi then no 3.3
@Phaedrux So what should my next steps be
Did you go through this?
What LEDs are lit?
@Phaedrux I completely missed the first time in my frustration but I did another once over to check fuses mofsets to see any physical damage and noticed fan fuse was blown I took it out plugged it in one more time to pc via usb and I had the greenlight turn on pronterface and it's I connected I didn't think the fan fuse would affect the 3.3v especially now since it's on and connected to pronterface with no fuse in it but I guess it's all good now back to hooking it up with my new duex on another note what's your advice on two separate psu one for duet 2 and one for duex 5 I see it's not recommened but I want to upgrade my bed heater and run more leds
