Nema 14 don't work with duet wifi drivers
@sigourosandreas Your stepper current is way too high; should be 450mA. Here's my motor config, which is otherwise much the same as your, for Orbiter v1.5 with 2.85mm Bondtech gears, but mostly the same, works great:
M584 X0 Y1 Z2:3 E4 ; Set drive mapping M569 P4 S0 ; physical drive 4 goes backwards M350 E16 I1 ; configure microstepping with interpolation M92 E743.50 ; set steps per mm M566 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 E3600.00 ; set maximum speeds (mm/min) M201 E600.00 ; set accelerations (mm/s^2) M906 E450 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
@droftarts thank you.
I tried it, but it does the same.
I really do not think it is current issue.
It must be something else, because it worked on a rambo board with about 900mA. -
@sigourosandreas Ah yes, sorry, I see you have the Wantai motor.
Have you tried it on a different motor driver on the Duet? It sounds like one of the phases may be disconnected.Ian
@sigourosandreas said in Nema 14 don't work with duet wifi drivers:
It must be something else, because it worked on a rambo board with about 900mA.Have you checked the pairs of coils are wired the correct way? that seems like the most likely cause to me (Not all motors use the same colours for the coil pairs unfortunately )
Looking at the Rambo board, the coils are wired the same way as Duet; one coil to the left pair of pins, one coil to the right pair.
@droftarts said in Nema 14 don't work with duet wifi drivers:
I wouldn't know about the Rambo TBH but it seems like a connection issue to me @sigourosandreas have you changed the std connectors from Dupont's onto Molex ones first if not I would put money on a poor connection on one or more pins!
Doug
Thanks for the help guys. All the motors are working.
I changed the pairs on the wirings and they are working.I had them BAAB ( like it is advised on the "duet wiring") and changed them to AABB and are moving.
I spent a month trying to solve this thing.
Thank you all.
@sigourosandreas you must have missed this: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers
The question is @sigourosandreas where BAAB is advised? In the Orbiter documentation? Because that's clearly wrong ...
@oliof no, it’s that there is no standard for describing how to connect the coils. We followed Trinamics naming for Duet 2 WiFi/ Ethernet, but even they changed it, which is why we ended up with (from the link I posted):
Each stepper motor connector has four pins. On Duet 2 WiFi/Ethernet these are labelled '2B 2A 1A 1B' on the back of the board, and on the wiring diagram. The '1' and '2' refer to the coil or phase, the 'A' and 'B' refer to the positive and negative.
On Duet 2 Maestro and Duet 3, the four motor connector pins are labelled 'B1 B2 A1 A2' on the back of the board and on the wiring diagram. The 'A' and 'B' refer to the coil or phase, the '1' and '2' refer to the positive and negative. This is the naming convention used by most stepper motor manufacturers.
