Your Duet rejected the HTTP request
so i got this error when i try to access my web control that my duet rejected the http request and i need to check the files in the www. folder. so in yat, which i finally got to connect, i ran m997 s1 and it tells me duetwifiserver.bin is not found. i dont know how to access the sd card without taking it out and going right into my computer, is there another way i can access it to check if my files somehow vanished, also how would these files just vanish because i was printing just fine yesterday. today it wont connect at all thanks for any help and for reading my issue.
Can you post the results of M122 from YAT?
Or M98 P"config.g"
M20 P"/www/" should read back the contents of the /www folder
What kind of a Duet is it?
my dislexia read that as m112 and ran an e stop on my board, its a duet 2 wifi. once i figure out why the hell it wont connect to yat ill post those but for some reason its always a serious struggle to get a terminal to connect. i had to unplug it to cancel the e stop and now it wont connect again
@Phaedrux this is the m122
=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-9T6BU-FG3SJ-6JTD4-3S86K-TAXZF<LF>Used output buffers: 1 of 24 (1 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93140 of which 0 recycled<LF>Exception stack ram used: 304<LF>Never used ram: 11916<LF>Tasks: NETWORK(ready,1448) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:04:04 ago, cause: power up<LF>Last software reset time unknown, reason: Unknown, spinning module Platform, available RAM 11996 bytes (slot 2)<LF>Software reset code 0x00b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x20001eac Task 0x5754454e<LF>Stack: 0044d797 00445546 6100f000 200176c0 0044d797 200176c0 00000000 200176b0 ffffffff 200176c0 20001778 2000065c 00000006 00000000 400c0000 20000660 0044d88f 200176b4 20001f08 200176b0 0044be77 00000014 00406599<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
@Phaedrux this is the m98 p "config.g"
HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is disabled<LF>ok<LF>
@Phaedrux so it looks like all my files are still there but i dont know why its not working, is there a way i can replace those files with what i have backed up on my computer without pulling the sd card? the only way i know to transfer files is on the web interface and since i cant get to it i feel like i have to take the card out and mess with it. to see the files and make sure everything is where its supposed to be
so idk if me doing that e stop is what reset everything but seems to be working now. what were you looking for in those cammands you had me run?
If the web interface files are missing (which sounds likely from the error message) you will need to manually copy them from your PC.
nvm, looks like it;s working now.
The commands were to check what duet and firmware you had, and see if the SD card was working.
@zshoe said in Your Duet rejected the HTTP request:
slot 0 detected and working.
These are responses from executing your config.g.
