Ender 5 plus - I need help
@Kanzleralexander Fans and BLTOUCH -Do not work
Is configuration correct? -
Can you provide the results of M122 and M98 P"config.g"? That would give us a good starting place.
There are some guides for using a duet with the Ender 3 that may be helpful to you. The Ender 3 and 5 are quite close.
https://duet3d.dozuki.com/Search?query=ender+3
@Kanzleralexander said in Ender 5 plus - I need help:
M950 F0 C"out6" Q20 ; create fan 0 on pin out6 and set its frequency
M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out7" Q20 ; create fan 1 on pin out7 and set its frequency
M950 F2 C"out8" Q20 ; create fan 2 on pin out8 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned onThe part cooling fan probably doesn't work because it's set to be thermostatically controlled to turn on at 45c.
Change this M106 P0 S1 H0 T45 to M106 P0 S1 H-1
what exactly doesn't work with the bltouch?
@Phaedrux my code:
Endstops
M574 X2 S1 P"!io0.in" ; configure active-high endstop for high end on X via pin !io0.in
M574 Y2 S1 P"!io1.in" ; configure active-high endstop for high end on Y via pin !io1.in
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io3.in" H5 F1800 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-44 Y-9 Z2.09 ; set Z probe trigger value, offset and trigger height
M557 X10:350 Y10:350 S20 ; define mesh gridAnd i find in Internet for Ender 5 :
Endstops
M574 Z0 ; disabled end stop for z
M574 X2 Y2 S1 ; set active high endstops; Filament Sensor
M591 D0 P1 S1 C3; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X60:300 Y30:300 S30 -
M106 P0 C"part-cooling" S0.65 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 C"hotend" S0.65 I0 F500 H1 T100 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0.85 I0 F500 H-1 -
Endstops
; Filament Sensor
M591 D0 P1 S1 C3
M557 X60:300 Y30:300 S30That's for firmware 2.x your current config is for the more recent version 3 firmware.
T100 mena sit won't turn the hot end heat sink fan until it's 100c which is hot enough to cause jamming. T45 is a better choice.
@Phaedrux said in Ender 5 plus - I need help:
Please provide this so we can see what firmware you're actually using.
sys\config.g
Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Mar 04 2021 02:49:06 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"My Printer" ; set printer name; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M350 X32 Y32 Z32 E128 I0 ; configure microstepping without interpolation
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X2 S1 P"io0.in" ; configure active-high endstop for high end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
G31 P500 X-44 Y-9 Z29 ; set Z probe trigger value, offset and trigger height
M557 X10:350 Y10:350 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T988801 B4185 C2200 ; configure sensor 0 as thermistor on pin temp0
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"temp1" Y"thermistor" T98801 B4185 C2200 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S260 ; set temperature limit for heater 1 to 260C; Fans
M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M501 ; load saved parameters from non-volatile memory -
Send M122 and M98 P"config.g" in the gcode console tab and post the results.
Also please describe what isn't working.
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mmthe steps you configured are for x16 microstepping
