Error: bad Command XXX W/RRF 3.2 and leveling issue
@martin7404 That is looking good! That's a genuine Hiwin rail and bearing with a slight preload?
@3DPrintingWorld yes , they are 3 Types thus is Z0
@3DPrintingWorld said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
Thats the issue!!! When I have the endstop on Duex5 I get a crash every 10-20 times, when its on wifi it works perfectly. I'll open a new issue on this but I think its related to the bed leveling issue as well because those motor are also on the duex 5. So is the Tool1 fan that turns on every other time for no reason.
You did update to 3.2.2?
Did you verify with M122? I've had occasions where the update seemed to go fine (no errors reported) but nothing actually was updated.
As you may recall I have 3 Z steppers on my Duex 5 along with their associated endstop sensors and 3.2.2 solved all of my problems with regards to missing endstop sensor activation.
@fcwilt Yes, switching to 3.2.2 fixed the issue. I was advised to start another thread because this one got long and contained too many topics. The endtop issue is now fixed, but I still have a issue with the bed leveling to an out of level plane.
So you started a new topic for that issue?
