BLTouch doesn't always deploy Duet 3 6HC
@User3D Yes. They are automatically generated if you select P9 as the probe type if i'm not mistaken. Here's a copy of mine
M280 P0 S10 ; deploy BLTouch
M280 P0 S90 ; retract BLTouch
@ctilley79 said in BLTouch doesn't always deploy Duet 3 6HC:
Yes they are, I just wanted to see if you've changed something that is causing all .
Any update on this? just broke a bltouch probe because of this issue.
I was having issues on IO_6, no deploy. checked wiring etc, all ok from that end. Changed to IO_7, now it works.
I've poked DC42 to take a look again when he has a moment.
Were you able to try a different BLTouch?
Hi was this issue solved? I’m having this issue ive brand new bltouch connected to io7
@bzad said in BLTouch doesn't always deploy Duet 3 6HC:
Probably best to start a new thread with your issue.
